Modelling and analysis of protein aggregation - completing pathways in prion (PrP) polymerisation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2014
Protein aggregation leading to the formation of amyloid fibrils is involved in several neurodegenerative diseases such as prion diseases. To clarify how these fibrils are able to incorporate additional units, prion fibril aggregation and disaggregation kinetics were experimentally studied using Static Light Scattering (SLS). Values that are functions of Σ i^2 c_i (for i >0) with c_i being the concentration of fibrils of size i, were then measured as a function of time. An initial model, adapted from the Becker-D¨oring system that considers all fibrils to react similarly is not able to reproduce the observed in vitro behaviour. Our second model involves an additional compartment of fibrils unable to incorporate more prion units. This model leads to kinetic coefficients which are biologically plausible and correctly simulates the first experimental steps for prion aggregation.
Fichier non déposé
hal-00958804 , version 1 (14-03-2014)
  • HAL Id : hal-00958804 , version 1
Stephanie Prigent, Hadjer Wafaa Haffaf. Modelling and analysis of protein aggregation - completing pathways in prion (PrP) polymerisation. 2014. ⟨hal-00958804⟩
309 Consultations
0 Téléchargements
