Object grammars and random generation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 1998
This paper presents a new systematic approach for the uniform random generation of combinatorial objects. The method is based on the notion of object grammars which give recursive descriptions of objects and generalize context-freegrammars. The application of particular valuations to these grammars leads to enumeration and random generation of objects according to non algebraic parameters.
dm020104.pdf (159.07 Ko) Télécharger le fichier
hal-00958902 , version 1 (13-03-2014)
I. Dutour, Jean-Marc Fedou. Object grammars and random generation. Discrete Mathematics and Theoretical Computer Science, 1998, Vol. 2, pp.49-63. ⟨10.46298/dmtcs.250⟩. ⟨hal-00958902⟩
165 Consultations
642 Téléchargements
