Minimum Eccentricity Multicast Trees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2001
We consider the problem of constructing a multicast tree that connects a group of source nodes to a group of sink nodes (receivers) and minimizes the maximum end-to-end delay between any pair of source/sink nodes. This is known as the \emphminimum eccentricity multicast tree problem, and is directly related to the quality of service requirements of real multipoint applications. We deal directly with the problem in its general form, meaning that the sets of source and sink nodes need not be overlapping nor disjoint. The main contribution of this work is a polynomial algorithm for this problem on general networks which is inspired by an innovative method that uses geometric relationships on the xy-plane.
dm040208.pdf (98.04 Ko) Télécharger le fichier
hal-00958955 , version 1 (13-03-2014)
David Krumme, Paraskevi Fragopoulou. Minimum Eccentricity Multicast Trees. Discrete Mathematics and Theoretical Computer Science, 2001, Vol. 4 no. 2 (2), pp.157-172. ⟨10.46298/dmtcs.278⟩. ⟨hal-00958955⟩
Collections
CNRS UVSQ TDS-MACS
171 Consultations
822 Téléchargements
