Optimal Sequential and Parallel Algorithms for Cut Vertices and Bridges on Trapezoid Graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2004
Let G be a graph. A component of G is a maximal connected subgraph in G. A vertex v is a cut vertex of G if k(G-v) > k(G), where k(G) is the number of components in G. Similarly, an edge e is a bridge of G if k(G-e) > k(G). In this paper, we will propose new O(n) algorithms for finding cut vertices and bridges of a trapezoid graph, assuming the trapezoid diagram is given. Our algorithms can be easily parallelized on the EREW PRAM computational model so that cut vertices and bridges can be found in O(log n) time by using O(n / log n) processors.
dm060220.pdf (132.13 Ko) Télécharger le fichier
hal-00959022 , version 1 (13-03-2014)
Hon-Chan Chen. Optimal Sequential and Parallel Algorithms for Cut Vertices and Bridges on Trapezoid Graphs. Discrete Mathematics and Theoretical Computer Science, 2004, Vol. 6 no. 2 (2), pp.483-496. ⟨10.46298/dmtcs.314⟩. ⟨hal-00959022⟩
Collections
TDS-MACS
75 Consultations
830 Téléchargements
