Connectedness of number theoretical tilings - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2005
Let T=T(A,D) be a self-affine tile in \reals^n defined by an integral expanding matrix A and a digit set D. In connection with canonical number systems, we study connectedness of T when D corresponds to the set of consecutive integers \0,1,..., |det(A)|-1\. It is shown that in \reals^3 and \reals^4, for any integral expanding matrix A, T(A,D) is connected. We also study the connectedness of Pisot dual tilings which play an important role in the study of β -expansion, substitution and symbolic dynamical system. It is shown that each tile generated by a Pisot unit of degree 3 is arcwise connected. This is naturally expected since the digit set consists of consecutive integers as above. However surprisingly, we found families of disconnected Pisot dual tiles of degree 4. Also we give a simple necessary and sufficient condition for the connectedness of the Pisot dual tiles of degree 4. As a byproduct, a complete classification of the β -expansion of 1 for quartic Pisot units is given.
dm070116.pdf (928.81 Ko) Télécharger le fichier
hal-00959042 , version 1 (13-03-2014)
Shigeki Akiyama, Nertila Gjini. Connectedness of number theoretical tilings. Discrete Mathematics and Theoretical Computer Science, 2005, Vol. 7, pp.269-312. ⟨10.46298/dmtcs.353⟩. ⟨hal-00959042⟩
Collections
TDS-MACS
69 Consultations
843 Téléchargements
