Multi-facet Document Representation and Retrieval - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents our participation in ImageCLEF2011, in the two tasks: ad-hoc image-based retrieval and case-based retrieval, of the medical retrieval track. We participated through a simple IR model based on three hypotheses: 1) the amount of overlap between a document and a query, 2) the descriptive power of an indexing element, and 3) the discriminative power of an indexing element. We used three types of indexing elements: ngrams, keywords, and concepts, for building and checking the e ectiveness of multi-facet document representation. Although of the simplicity of our model in both documents' representation and retrieval, we could obtain good results. The eighth out of 64 runs in the ad-hoc image-based retrieval task, and the fth out of 35 runs in the case-based retrieval task.
Abdulahhad-Chevallet-Berrut_CLEF2011.pdf (111.74 Ko) Télécharger le fichier
hal-00764761 , version 1 (13-12-2012)
  • HAL Id : hal-00764761 , version 1
Karam Abdulahhad, Jean-Pierre Chevallet, Catherine Berrut. Multi-facet Document Representation and Retrieval. CLEF 2011 - Conference on Multilingual and Multimodal Information Access Evaluation, Sep 2011, Amsterdam, Netherlands. 9p. ⟨hal-00764761⟩
280 Consultations
214 Téléchargements
