NUMERICAL SIMULATIONS OF THE PERIODIC INVISCID BURGERS EQUATION WITH STOCHASTIC FORCING - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ouvrage (Y Compris Édition Critique Et Traduction) Année : 2015
Emmanuel Audusse
Yueyuan Gao
  • Fonction : Directeur scientifique
  • PersonId : 954152
Danielle Hilhorst
We perform numerical simulations in the one-dimensional torus for the first order Burgers equation forced by a stochastic source term with zero spatial integral. We suppose that this source term is a white noise in time, and consider various egularities in space. For the numerical tests, we apply a finite volume scheme combining the Godunov numerical flux with the Euler-Maruyama integrator in time. Our Monte-Carlo simulations are analyzed in bounded time intervals as well as in the large time limit, for various regularities in space. The empirical mean always converges to the space-average of the (deterministic) initial condition as t → ∞, just as the solution of the deterministic problem without source term, even if the stochastic source term is very rough. The empirical variance also stablizes for large time, towards a limit which depends on the space regularity and on the intensity of the noise.
ABGH-22-juin.pdf (349.85 Ko) Télécharger le fichier
hal-00962213 , version 1 (24-03-2014)
hal-00962213 , version 2 (27-06-2014)
  • HAL Id : hal-00962213 , version 2
Emmanuel Audusse, Sébastien Boyaval, Yueyuan Gao, Danielle Hilhorst (Dir.). NUMERICAL SIMULATIONS OF THE PERIODIC INVISCID BURGERS EQUATION WITH STOCHASTIC FORCING. 48, pp.308-320, 2015, ESAIM: Proceedings and Surveys. ⟨hal-00962213v2⟩
483 Consultations
1321 Téléchargements
