Randomized pick-freeze for sparse Sobol indices estimation in high dimension - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
This article investigates a new procedure to estimate the influence of each variable of a given function defined on a high-dimensional space. More precisely, we are concerned with describing a function of a large number $p$ of parameters that depends only on a small number $s$ of them. Our proposed method is an unconstrained $\ell_{1}$-minimization based on the Sobol's method. We prove that, with only $\mathcal O(s\log p)$ evaluations of $f$, one can find which are the relevant parameters.
ArticleRandomPF_2014_03_17.pdf (257.45 Ko) Télécharger le fichier
hal-00962473 , version 1 (21-03-2014)
Yohann de Castro, Alexandre Janon. Randomized pick-freeze for sparse Sobol indices estimation in high dimension. [Research Report] 2014. ⟨hal-00962473⟩
300 Consultations
233 Téléchargements
