Analysis of scale invariance property applying homogeneity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The problem of scalability of trajectories in homogeneous and locally homogeneous systems is considered. It is shown that the homogeneous systems have scalability property, and locally homogeneous systems possess this property approximately. The issue of closeness of trajectories for the system and its local homogeneous approximation is investigated. The notions of scale invariance and fold change detection are also studied. The results are illustrated by a cascade system analysis.
Automatique
Homogeneity_for_a_class_of_biological_systems_IFAC.pdf (153.22 Ko) Télécharger le fichier
hal-00964081 , version 1 (26-03-2014)
  • HAL Id : hal-00964081 , version 1
Emmanuel Bernuau, Denis Efimov, Wilfrid Perruquetti. Analysis of scale invariance property applying homogeneity. 19th IFAC World Congress 2014, Aug 2014, Cape Town, South Africa. ⟨hal-00964081⟩
245 Consultations
176 Téléchargements
