A generating algorithm for ribbon tableaux and spin polynomials - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2006
Francois Descouens
  • Fonction : Auteur
  • PersonId : 836719
We describe a general algorithm for generating various families of ribbon tableaux and computing their spin polynomials. This algorithm is derived from a new matricial coding. An advantage of this new notation lies in the fact that it permits one to generate ribbon tableaux with skew shapes. This algorithm permits us to compute quickly big LLT polynomials in MuPAD-Combinat.
generation_rubans_arxiv.pdf (141.89 Ko) Télécharger le fichier
hal-00116692 , version 1 (27-11-2006)
Francois Descouens. A generating algorithm for ribbon tableaux and spin polynomials. 2006. ⟨hal-00116692⟩
191 Consultations
80 Téléchargements
