An optimal permutation routing algorithm on full-duplex hexagonal networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2008
In the permutation routing problem, each processor is the origin of at most one packet and the destination of no more than one packet. The goal is to minimize the number of time steps required to route all packets to their respective destinations, under the constraint that each link can be crossed simultaneously by no more than one packet. We study this problem in a hexagonal network, i.e. a finite subgraph of a triangular grid, which is a widely used network in practical applications. We present an optimal distributed permutation routing algorithm on full-duplex hexagonal networks, using the addressing scheme described by F.G. Nocetti, I. Stojmenovic and J. Zhang (IEEE TPDS 13(9): 962-971, 2002). Furthermore, we prove that this algorithm is oblivious and translation invariant.
960-3471-3-PB.pdf (102.44 Ko) Télécharger le fichier
hal-00972334 , version 1 (03-04-2014)
Ignasi Sau, Janez Žerovnik. An optimal permutation routing algorithm on full-duplex hexagonal networks. Discrete Mathematics and Theoretical Computer Science, 2008, Vol. 10 no. 3 (3), pp.49--62. ⟨10.46298/dmtcs.443⟩. ⟨hal-00972334⟩
461 Consultations
1008 Téléchargements
