A Simple Tool for Automatic Extraction of Moroccan Coastal Upwelling from Sea Surface Temperature Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This work aims at automatically identify and ex- tract the region covered by the upwelling waters in the costal ocean of Morocco using the well known region-growing segmen- tation algorithm. The later consists in coarse segmentation of upwelling area which characterized by cold and usually nutrient- rich water near the coast. The complete system has been validated by an oceanographer over a database of 30 Sea Surface Tem- perature (SST) satellite images of the year 2007 obtained from Advanced Very High Resolution Radiometer (AVHRR) sensor onboard NOAA-18 satellite serie, demonstrating its capability and effectiveness to reproduce the shape of upwelling area.
SITA_Updated.pdf (371.06 Ko) Télécharger le fichier
hal-00973756 , version 1 (04-04-2014)
  • HAL Id : hal-00973756 , version 1
Ayoub Tamim, Khalid Minaoui, Khalid Daoudi, Abderrahman Atillah, Hussein Yahia, et al.. A Simple Tool for Automatic Extraction of Moroccan Coastal Upwelling from Sea Surface Temperature Images. SITA'14 - 9th International Conference on Intelligent Systems: Theories and Applications, IEEE, May 2014, Rabat, Morocco. ⟨hal-00973756⟩
296 Consultations
641 Téléchargements
