A simple derivation of BV bounds for inhomogeneous relaxation systems
We consider relaxation systems of transport equations with heterogeneous source terms and with boundary conditions, which limits are scalar conservation laws. Classical bounds fail in this context and in particular BV estimates. They are the most standard and simplest way to prove compactness and convergence. We provide a novel and simple method to obtain partial BV regularity and strong compactness in this framework. The standard notion of entropy is not convenient either and we also indicate another, but closely related, notion. We give two examples motivated by renal flows which consist of 2 by 2 and 3 by 3 relaxation systems with 2-velocities but the method is more general.
