A NEW APPROACH TO IMPROVE ILL-CONDITIONED PARABOLIC OPTIMAL CONTROL PROBLEM VIA TIME DOMAIN DECOMPOSITION - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
In this paper we present a new steepest-descent type algorithm for convex optimization problems. Our algorithm pieces the unknown into sub-blocs of unknowns and considers a partial optimization over each sub-bloc. In quadratic optimization, our method involves Newton technique to compute the step-lengths for the sub-blocs resulting descent directions. Our optimization method is fully parallel and easily implementable, we first presents it in a general linear algebra setting, then we highlight its applicability to a parabolic optimal control problem, where we consider the blocs of unknowns with respect to the time dependency of the control variable. The parallel tasks, in the last problem, turn``on" the control during a specific time-window and turn it ``off" elsewhere. We show that our algorithm significantly improves the computational time compared with recognized methods. Convergence analysis of the new optimal control algorithm is provided for an arbitrary choice of partition. Numerical experiments are presented to illustrate the efficiency and the rapid convergence of the method.
riahi_PSDQN.pdf (1.27 Mo) Télécharger le fichier
hal-00974285 , version 1 (06-04-2014)
hal-00974285 , version 2 (14-01-2015)
hal-00974285 , version 3 (04-11-2020)
Copyright (Tous droits réservés)
  • HAL Id : hal-00974285 , version 3
Mohamed-Kamel Riahi. A NEW APPROACH TO IMPROVE ILL-CONDITIONED PARABOLIC OPTIMAL CONTROL PROBLEM VIA TIME DOMAIN DECOMPOSITION. 2020. ⟨hal-00974285v3⟩
Collections
TDS-MACS
272 Consultations
1158 Téléchargements
