Fast and accurate computation of layer heat potentials - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Scientific Computing Année : 2009
We discuss the numerical evaluation of single and double layer heat potentials in two dimensions on stationary and moving boundaries. One of the principal difficulties in designing high order methods concerns the local behavior of the heat kernel, which is both weakly singular in time and rapidly decaying in space. We show that standard quadrature schemes suffer from a poorly recognized form of inaccuracy, which we refer to as “geometrically-induced stiffness”, but that rules based on product integration of the full heat kernel in time are robust. When combined with previously developed fast algorithms for the evolution of the “history part” of layer potentials, diffusion processes in complex, moving geometries can be computed accurately and in nearly optimal time.
Fichier non déposé
hal-00975973 , version 1 (09-04-2014)
  • HAL Id : hal-00975973 , version 1
Jing-Rebecca Li, Leslie Greengard. Fast and accurate computation of layer heat potentials. SIAM Journal on Scientific Computing, 2009. ⟨hal-00975973⟩
102 Consultations
0 Téléchargements
