An Introduction to Optimization Techniques in Computer Graphics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Document Associé À Des Manifestations Scientifiques Année : 2014
Background: Many students in Computer Science do not have a sufficient background in applied mathematics to employ state-of-the-art optimization techniques and to judge the outcome of such techniques critically (e.g. regarding the stability/quality/accuracy of their output). At the same time, the use of optimization techniques in computer graphics is becoming ubiquitous. Treating optimization algorithms as a black box yields sub-optimal results at best. At worst, stability issues and convergence problems may prevent the solution of a problem or impede the general application of a method to a wide range of input, i.e. beyond the set of examples shown in a paper. The course will draw attention to these aspects and to current best practices. This will enable participants to judge articles that use optimization schemes critically and improve their own skill set.
04_variational_methods.pdf (5.74 Mo) Télécharger le fichier
01_least_squares.pptx (5.24 Mo) Télécharger le fichier
02_numerical_linalg.odp (4.51 Mo) Télécharger le fichier
03_inverse_problems.pptx (42.15 Mo) Télécharger le fichier
05_compressive_sensing.pdf (12.07 Mo) Télécharger le fichier
Format : Autre
Format : Autre
Format : Autre
hal-00976357 , version 1 (16-05-2014)
Ivo Ihrke, Xavier Granier, Gaël Guennebaud, Laurent Jacques, Bastian Goldluecke. An Introduction to Optimization Techniques in Computer Graphics. Eurographics 2014 - Tutorials, Apr 2014, Strasbourg, France. 2014, ⟨10.2312/egt.20141019⟩. ⟨hal-00976357⟩
557 Consultations
2031 Téléchargements
