Scalar conservation laws with moving constraints arising in traffic flow modeling: an existence result - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Differential Equations Année : 2014
We consider a strongly coupled PDE-ODE system that describes the influence of a slow and large vehicle on road traffic. The model consists of a scalar conservation law accounting for the main traffic evolution, while the trajectory of the slower vehicle is given by an ODE depending on the downstream traffic density. The moving constraint is expressed by an inequality on the flux, which models the bottleneck created in the road by the presence of the slower vehicle. We prove the existence of solutions to the Cauchy problem for initial data of bounded variation.
ExistenceBus.pdf (182.98 Ko) Télécharger le fichier
hal-00976855 , version 1 (10-04-2014)
  • HAL Id : hal-00976855 , version 1
Maria Laura Delle Monache, Paola Goatin. Scalar conservation laws with moving constraints arising in traffic flow modeling: an existence result. Journal of Differential Equations, 2014, 257, pp.4015-4029. ⟨hal-00976855⟩
617 Consultations
734 Téléchargements
