Existence and diffusive limit of a two-species kinetic model of chemotaxis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Kinetic and Related Models Année : 2015
In this paper, we propose a kinetic model describing the collective motion by chemotaxis of two species in interaction emitting the same chemoattractant. Such model can be seen as a generalisation to several species of the Othmer-Dunbar-Alt model which takes into account the run-and-tumble process of bacteria. Existence of weak solutions for this two-species kinetic model is studied and the convergence of its diffusive limit towards a macroscopic model of Keller-Segel type is analysed.
kinmulti_v2.pdf (266.54 Ko) Télécharger le fichier
hal-00980594 , version 1 (18-04-2014)
Luís Almeida, Casimir Emako, Nicolas Vauchelet. Existence and diffusive limit of a two-species kinetic model of chemotaxis. Kinetic and Related Models , 2015, ⟨10.3934/krm.2015.8.359⟩. ⟨hal-00980594⟩
511 Consultations
330 Téléchargements
