Improved bounds on the crossing number of butterfly network - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2013
We draw the r-dimensional butterfly network with 1 / 44r+O(r2r) crossings which improves the previous estimate given by Cimikowski (1996). We also give a lower bound which matches the upper bound obtained in this paper.
1807-7889-1-PB.pdf (228.31 Ko) Télécharger le fichier
hal-00980758 , version 1 (18-04-2014)
Paul D. Manuel, Bharati Rajan, Indra Rajasingh, P. Vasanthi Beulah. Improved bounds on the crossing number of butterfly network. Discrete Mathematics and Theoretical Computer Science, 2013, Vol. 15 no. 2 (2), pp.87--94. ⟨10.46298/dmtcs.611⟩. ⟨hal-00980758⟩
Collections
TDS-MACS
124 Consultations
1068 Téléchargements
