An efficient numerical method for the resolution of the Kirchhoff-Love dynamic plate equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Numerical Methods for Partial Differential Equations Année : 2005
We solve numerically the Kirchhoff-Love dynamic plate equation for an anisotropic heterogeneous material using a spectral method. A mixed velocity-moment formulation is proposed for the space approximation allowing the use of classical Lagrange finite elements. The benefit of using high order elements is shown through a numerical dispersion analysis. The system resulting from this spatial discretization is solved analytically. Hence this method is particularly efficient for long duration experiments. This time evolution method is compared with explicit and implicit finite differences schemes in terms of accuracy and computation time. © 2004 Wiley Periodicals, Inc. Numer Methods Partial Differential Eq, 2005
hal-00982754 , version 1 (24-04-2014)
Eliane Bécache, Grégoire Derveaux, Patrick Joly. An efficient numerical method for the resolution of the Kirchhoff-Love dynamic plate equation. Numerical Methods for Partial Differential Equations, 2005, 21 (2), pp.323 - 348. ⟨10.1002/num.20041⟩. ⟨hal-00982754⟩
182 Consultations
0 Téléchargements
