AnaVANET: an experiment and visualization tool for vehicular networks
The experimental evaluation of wireless and mobile networks is a challenge that rarely substitutes simulation in research works. This statement is even more evident in vehicular communications, due to the equipment and effort needed to obtain significant and realistic results. In this paper, key issues in vehicular experimental evaluation are analyzed by an evaluation tool called AnaVANET, especially designed for assessing the performance of vehicular networks. This software processes the output of well-known testing tools such as ping or iperf, together with navigation information, to generate geo-aware performance figures of merit both in numeric and graphical forms. Its main analysis capabilities are used to validate the good performance in terms of delay, packet delivery ratio and throughput of NEMO, when using a road-side segment based on IPv6 GeoNetworking.
tridentcom2014.pdf (1.33 Mo)
Télécharger le fichier
20140506-TridentCom-AnaVANET.pdf (5.28 Mo)
Format : Autre
