A Survey on (mobile) wireless sensor network experimentation testbeds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
With the development of new technologies, these last years have witnessed the emergence of a new paradigm: the Internet of Things (IoT) and of the physical world. We are now able to communicate and interact with our surrounding environ- ment through the use of multiple tiny sensors, RFID technologies or small wireless robots. This allows a set of new applications and usages to be envisioned ranging from logistic and traceability purposes to emergency and rescue operations going through the monitoring of volcanos or forest fires. However, all this comes with several technical and scientific issues like how to ensure the reliability of wireless communications in disturbed environments, how to manage efficiently the low resources (energy, memory, etc) or how to set a safe and sustainable maintenance. All these issues are addressed by researchers all around the world but solutions designed for IoT need to face real experimentations to be validated. To ease such experimentations for IoT, several experimental testbeds have been deployed offering diverse and heterogeneous services and tools. This article studies the different requirements and features such facilities should offer and survey the different experimental facilities currently available for the community, the different hardware used (as sensors and robots) and the scope of their services. We expect this survey assist a potential user to easily choose the one to use regarding his own needs. Finally, we identify existing gaps and difficulties and investigate new directions for such facilities.
dcoss4618a263.pdf (257.08 Ko) Télécharger le fichier
hal-00988776 , version 1 (18-07-2014)
  • HAL Id : hal-00988776 , version 1
Anne-Sophie Tonneau, Nathalie Mitton, Julien Vandaele. A Survey on (mobile) wireless sensor network experimentation testbeds. DCOSS - IEEE International Conference on Distributed Computing in Sensor Systems, May 2014, Marina Del Rey, California, United States. ⟨hal-00988776⟩
440 Consultations
865 Téléchargements
