The Laplacian spread of Cactuses - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2010
Connected graphs in which any two of its cycles have at most one common vertex are called cactuses. In this paper, we continue the work on Laplacian spread of graphs, and determine the graph with maximal Laplacian spread in all cactuses with n vertices.
1301-5061-2-PB.pdf (212.33 Ko) Télécharger le fichier
hal-00990441 , version 1 (13-05-2014)
Ying Liu. The Laplacian spread of Cactuses. Discrete Mathematics and Theoretical Computer Science, 2010, Vol. 12 no. 3 (3), pp.35-40. ⟨10.46298/dmtcs.488⟩. ⟨hal-00990441⟩
Collections
TDS-MACS
61 Consultations
940 Téléchargements
