Sustainable data for sustainable infrastructures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2014
DARIAH, the Digital Research Infrastructure for the Arts and Humanities, is committed to advancing the digital revolution that has captured the arts and humanities. As more legacy primary and secondary sources become digital, more digital content is being produced and more digital tools are being deployed, we see a next generation of digitally aware scholars in the humanities emerge. DARIAH aims to connect these resources, tools and scholars, ensuring that the state-of-the-art in research is sustained and integrated across European countries. To do so, it is important to understand the actual role that proper data modelling and standards could play to make digital content sustainable. Even if it does not seem obvious at first sight that the arts and humanities would be fit for taking up the technological prerequisites of standardisation, we want to show in this paper that we can and should integrate standardisation issues at the core of our DARIAH infrastructural work. This analysis may lead us to a wider understanding of the role of scholars within a digital infrastructure and consequently on how DARIAH could better integrate a variety of research communities in the arts and humanities.
Romary_HAL.pdf (169.07 Ko) Télécharger le fichier
hal-00992220 , version 1 (16-05-2014)
  • HAL Id : hal-00992220 , version 1
Laurent Romary. Sustainable data for sustainable infrastructures. Adrian Duşa and Dietrich Nelle and Günter Stock and Gert G. Wagner. Facing the Future: European Research Infrastructures for the Humanities and Social Sciences, SCIVERO Verlag, 2014. ⟨hal-00992220⟩
432 Consultations
217 Téléchargements
