System-level State Equality Detection for the Dynamic Verification of Distributed Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Marion Guthmuller
  • Fonction : Auteur
  • PersonId : 891939
Martin Quinson
This poster presents our solution to detect state equality of legacy MPI applications directly at system level, which is important to formally verify these applications.
2014-eurosys-abstract.pdf (26.07 Ko) Télécharger le fichier
2014-eurosys.pdf (616.4 Ko) Télécharger le fichier
Format : Autre
hal-00997941 , version 1 (29-05-2014)
  • HAL Id : hal-00997941 , version 1
Marion Guthmuller, Martin Quinson. System-level State Equality Detection for the Dynamic Verification of Distributed Applications. EuroSys - 9th European Conference on Computer Systems, Apr 2014, Amsterdam, Netherlands. ⟨hal-00997941⟩
183 Consultations
88 Téléchargements
