Taxonomy of Coding Techniques for Efficient Network Communications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2018
This document summarizes recommended terminology for Network Coding concepts and constructs. It provides a comprehensive set of terms in order to avoid ambiguities in future IRTF and IETF documents on Network Coding. This document is the product of the Coding for Efficient Network Communications Research Group (NWCRG), and it is in line with the terminology used by the RFCs produced by the Reliable Multicast Transport (RMT) and FEC Framework (FECFRAME) IETF working groups.
rfc8406.pdf (22.54 Ko) Télécharger le fichier
hal-00998506 , version 1 (02-06-2014)
hal-00998506 , version 2 (02-12-2014)
hal-00998506 , version 3 (07-11-2017)
hal-00998506 , version 4 (12-11-2018)
  • HAL Id : hal-00998506 , version 4
Brian Adamson, Cédric Adjih, Josu Bilbao, Victor Firoiu, Frank Fitzek, et al.. Taxonomy of Coding Techniques for Efficient Network Communications. 2018. ⟨hal-00998506v4⟩
886 Consultations
512 Téléchargements
