Stabilizing Heteroscedastic Noise With the Generalized Anscombe Transform. Application to Accurate Prediction of the Resolution in Displacement and Strain Maps Obtained With the Grid Method. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Michel Grediac
  • Fonction : Auteur
  • PersonId : 866100
The objective of this paper is to show that it is possible to predict the noise level in displacement and strain maps obtained with the grid method, but that actual noise of camera sensors being heteroscedastic, it is necessary to stabilize this noise in grid images prior to employing the predicting formulas. The procedure used for this purpose relies on the Generalized Anscombe Transform. This transform is first described. It is then shown that experimental and theoretical resolutions in strain maps obtained with the grid method are in good agreement when this transform is employed.
SEM2014_GS.pdf (346.49 Ko) Télécharger le fichier
hal-01001869 , version 1 (12-09-2014)
Michel Grediac, Frédéric Sur. Stabilizing Heteroscedastic Noise With the Generalized Anscombe Transform. Application to Accurate Prediction of the Resolution in Displacement and Strain Maps Obtained With the Grid Method.. SEM Annual Conference & Exposition on Experimental and Applied Mechanics - 2014, Jun 2014, Greenville, SC, United States. pp.225-230, ⟨10.1007/978-3-319-06986-9_25⟩. ⟨hal-01001869⟩
259 Consultations
328 Téléchargements
