Maximum Likelihood-based Online Adaptation of Hyper-parameters in CMA-ES - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The Covariance Matrix Adaptation Evolution Strategy (CMA-ES) is widely accepted as a robust derivative-free continuous optimization algorithm for non-linear and non-convex optimization problems. CMA-ES is well known to be almost parameterless, meaning that only one hyper-parameter, the population size, is proposed to be tuned by the user. In this paper, we propose a principled approach called self-CMA-ES to achieve the online adaptation of CMA-ES hyper-parameters in order to improve its overall performance. Experimental results show that for larger-than-default population size, the default settings of hyper-parameters of CMA-ES are far from being optimal, and that self-CMA-ES allows for dynamically approaching optimal settings.
selfCMA.pdf (991.45 Ko) Télécharger le fichier
hal-01003504 , version 1 (10-06-2014)
hal-01003504 , version 2 (11-06-2014)
Ilya Loshchilov, Marc Schoenauer, Michèle Sebag, Nikolaus Hansen. Maximum Likelihood-based Online Adaptation of Hyper-parameters in CMA-ES. 13th International Conference on Parallel Problem Solving from Nature (PPSN 2014), Sep 2014, Ljubljana, Slovenia. pp.70-79. ⟨hal-01003504v2⟩
501 Consultations
370 Téléchargements
