Which fMRI clustering gives good brain parcellations? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Frontiers in Neuroscience Année : 2014
Analysis and interpretation of neuroimaging data often require one to divide the brain into a number of regions, or parcels, with homogeneous characteristics, be these regions defined in the brain volume or on on the cortical surface. While predefined brain atlases do not adapt to the signal in the individual subjects images, parcellation approaches use brain activity (e.g. found in some functional contrasts of interest) and clustering techniques to define regions with some degree of signal homogeneity. In this work, we address the question of which clustering technique is appropriate and how to optimize the corresponding model. We use two principled criteria: goodness of fit (accuracy), and reproducibility of the parcellation across bootstrap samples. We study these criteria on both simulated and two task-based functional Magnetic Resonance Imaging datasets for the Ward, spectral and K-means clustering algorithms. We show that in general Ward's clustering performs better than alternative methods with regard to reproducibility and accuracy and that the two criteria diverge regarding the preferred models (reproducibility leading to more conservative solutions), thus deferring the practical decision to a higher level alternative, namely the choice of a trade-off between accuracy and stability.
frontiers_paper.pdf (533 Ko) Télécharger le fichier
hal-01015172 , version 1 (25-06-2014)
Bertrand Thirion, Gaël Varoquaux, Elvis Dohmatob, Jean-Baptiste Poline. Which fMRI clustering gives good brain parcellations?. Frontiers in Neuroscience, 2014, 8 (167), pp.13. ⟨10.3389/fnins.2014.00167⟩. ⟨hal-01015172⟩
591 Consultations
622 Téléchargements
