A generator of random convex polygons in a disc - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2014
Olivier Devillers
Rémy Thomasse
  • Fonction : Auteur
  • PersonId : 950273
We propose an algorithm that generates a random polygon as a convex hull of n points uniformly and independently distributed in a disc without explicitly generate all the points.
generator_aofa.pdf (110.04 Ko) Télécharger le fichier
poster-Generator-Remy.pdf (181.3 Ko) Télécharger le fichier
Format : Figure, Image
Format : Autre
hal-01015603 , version 1 (26-06-2014)
  • HAL Id : hal-01015603 , version 1
Olivier Devillers, Philippe Duchon, Rémy Thomasse. A generator of random convex polygons in a disc. AofA 2014- 25th International Conference on Probabilistic, Combinatorial and Asymptotic Methods for the Analysis of Algorithms, Jun 2014, Paris, France. ⟨hal-01015603⟩
347 Consultations
848 Téléchargements
