Recognizing shrinkable complexes is NP-complete - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Olivier Devillers
Marc Glisse
We say that a simplicial complex is shrinkable if there exists a sequence of admissible edge contractions that reduces the complex to a single vertex. We prove that it is NP-complete to decide whether a (three-dimensional) simplicial complex is shrinkable. Along the way, we describe examples of contractible complexes which are not shrinkable.
esa.pdf (1.36 Mo) Télécharger le fichier
Format : Figure, Image
hal-01015747 , version 1 (27-06-2014)
Dominique Attali, Olivier Devillers, Marc Glisse, Sylvain Lazard. Recognizing shrinkable complexes is NP-complete. ESA 2014 - 22nd Annual European Symposium on Algorithms, Sep 2014, Wroclaw, Poland. pp.74-86, ⟨10.1007/978-3-662-44777-2_7⟩. ⟨hal-01015747⟩
774 Consultations
558 Téléchargements
