State of the Art in Surface Reconstruction from Point Clouds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The area of surface reconstruction has seen substantial progress in the past two decades. The traditional problem addressed by surface reconstruction is to recover the digital representation of a physical shape that has been scanned, where the scanned data contains a wide variety of defects. While much of the earlier work has been focused on reconstructing a piece-wise smooth representation of the original shape, recent work has taken on more specialized priors to address significantly challenging data imperfections, where the reconstruction can take on different representations -- not necessarily the explicit geometry. This state-of-the-art report surveys the field of surface reconstruction, providing a categorization with respect to priors, data imperfections, and reconstruction output. By considering a holistic view of surface reconstruction, this report provides a detailed characterization of the field, highlights similarities between diverse reconstruction techniques, and provides directions for future work in surface reconstruction.
Mots clés
star_author.pdf (2 Mo) Télécharger le fichier
Format : Figure, Image
hal-01017700 , version 1 (03-07-2014)
Matthew Berger, Andrea Tagliasacchi, Lee Seversky, Pierre Alliez, Joshua Levine, et al.. State of the Art in Surface Reconstruction from Point Clouds. Eurographics 2014 - State of the Art Reports, Apr 2014, Strasbourg, France. pp.161-185, ⟨10.2312/egst.20141040⟩. ⟨hal-01017700⟩
4309 Consultations
13871 Téléchargements
