Analytically-Based Simulation for Corrosion Detection by Guided Waves
To create a theoretical basis for guided wave detection and identification of corrosion damages, a set of analytically based computer models of various complexity has been developed. The present paper is focused on the simplest and fastest beam model for stepped and notched waveguides, which has exhibited a wide frequency range of reasonable coincidence with the results obtained within more complex integral equation based model for a 2D notched elastic strip.
