ADALINE Network-Based Temperature Compensation Method for SHM Method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The performance of current PZTs array and Lamb wave based SHM methods is restricted by the temperature variation. As temperature has a significant influence on Lamb wave propagation which leading to false monitoring result even if the structure is under health status. A new temperature compensation method based on adaptive filter adaptive liner neural (ADALINE) network has been developed to compensate for the amplitude-change and phase-shift of Lamb wave due to temperature change. Network construction and procedure of compensation are discussed. The advantages of this proposed method are (1) Simple to be applied, (2) only a few baselines are required for a large temperature range. Experiments are conducted on a stiffened carbon fiber composite panel to verify the temperature compensation method under temperature range from -40ÁC to 80ÁC. Results show the presented method is effective. Damage image combined with this compensation method can detect the damage under temperature variations.
0098.pdf (597.29 Ko) Télécharger le fichier
hal-01020369 , version 1 (08-07-2014)
  • HAL Id : hal-01020369 , version 1
Tianxiang Huang, Shenfang Yuan, Lei Qiu. ADALINE Network-Based Temperature Compensation Method for SHM Method. EWSHM - 7th European Workshop on Structural Health Monitoring, IFFSTTAR, Inria, Université de Nantes, Jul 2014, Nantes, France. ⟨hal-01020369⟩
175 Consultations
179 Téléchargements
