Quantitative Strain Measurement with Distributed Fiber Optic Systems: Qualification of a Sensing Cable Bonded to the Surface of a Concrete Structure - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Distributed Fiber Optic Systems (DOFS) are an emerging and innovative technology that allows long-range and continuous strain/temperature monitoring with a high resolution. However, strain profiles measured in the optical fiber may differ from actual strain in the structure, due to the shear transfer through the intermediate material layers between the optical fiber and the host material (i.e., in the protective coating of the sensing cable and in the adhesive). Therefore, fiber optic sensors need to be qualified in order to provide accurate quantitative strain measurements. This study presents a methodology for the qualification of a DOFS. It is proposed to establish a numerical modeling of the system, in which the mechanical parameters are calibrated from experiments. A specific surface-mounted sensing cable connected to an Optical Frequency Reflectometry Domain (OFDR) interrogator is considered as case study. We found that (i) tensile and pull-out tests are able to provide full information about materials and interfaces of our modeling, (ii) the calibrated model allows us to compute strain profiles along the optical fiber, (iii) which proved to be consistent with strain profiles measured on a cracked concrete beam during a 4-points bending test.
0079.pdf (1.27 Mo) Télécharger le fichier
hal-01022049 , version 1 (10-07-2014)
  • HAL Id : hal-01022049 , version 1
Astrid Billon, Jean-Marie Henault, Marc Quiertant, Frédéric Taillade, Aghiad Khadour, et al.. Quantitative Strain Measurement with Distributed Fiber Optic Systems: Qualification of a Sensing Cable Bonded to the Surface of a Concrete Structure. EWSHM - 7th European Workshop on Structural Health Monitoring, IFFSTTAR, Inria, Université de Nantes, Jul 2014, Nantes, France. ⟨hal-01022049⟩
509 Consultations
628 Téléchargements
