Ultrasonic Verification of Composite Structures
Ultrasonic Verification is a new method for the monitoring large surface areas of CFRP by ultrasound with few sensors. The echo response of a transmitted pulse through the structure is compared with the response of an earlier obtained reference signal to calculate a fidelity parameter. A change in fidelity over time is indicative for a new defect in the structure. This paper presents an experimental assessment of the effectiveness and reproducibility of the method.
