Bang bang trajectories with a double switching time in the minimum time problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Document Associé À Des Manifestations Scientifiques Année : 2014
We consider the minimum time problem with xed end-points on a finite dimensional manifold M in the case when the dynamics is a ne with respect to the control and the control set is a box in R^m. We are interested in giving sufficient conditions for strong local optimality. Our sufficient conditions are given using Hamiltonian methods, but here the presence of a double switch makes the proof of the local invertibility of the maximized Hamiltonian flow much more tricky.
Poggiolini-NETCO2014.pdf (375.13 Ko) Télécharger le fichier
hal-01024733 , version 1 (18-07-2014)
  • HAL Id : hal-01024733 , version 1
Laura Poggiolini, Marco Spadini, Gianna Stefani. Bang bang trajectories with a double switching time in the minimum time problem. NETCO 2014 - New Trends in Optimal Control, Jun 2014, Tours, France. ⟨hal-01024733⟩
92 Consultations
120 Téléchargements
