Necessary Conditions for Implicit and DAE Control Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Document Associé À Des Manifestations Scientifiques Année : 2014
Necessary conditions for optimal control problems involving implicit control systems and with possible nonsmooth data has been derived under bounded slope conditions in [1]. Here, we investigate how such conditions apply to various particular cases of implicit control systems. In particular, we extend the analysis in [3], where application to some optimal control problems with semi-explicit Differential Algebraic Equations (DAE's) are explored. Noteworthy, we consider DAE's systems with index higher then 1. We go a step further and we extend necessary conditions for mixed constrained problem derived in [3] under interiority conditions and convexity of the velocity sets can to cover implicit control systems.
dePinho-NETCO2014.pdf (7.42 Mo) Télécharger le fichier
hal-01024782 , version 1 (16-07-2014)
  • HAL Id : hal-01024782 , version 1
Maria Do Rosário de Pinho. Necessary Conditions for Implicit and DAE Control Systems. NETCO 2014 - New Trends in Optimal Control, Jun 2014, Tours, France. ⟨hal-01024782⟩
258 Consultations
64 Téléchargements
