MPLM -- MaTeLo Product Line Manager - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ralf Bogusch
  • Fonction : Auteur
  • PersonId : 957176
The diversity of requirements elicited from different customers leads to the development of many variants. Furthermore, compliance with safety standards as mandated for safety-critical systems requires high test efforts for each variant. Model-based testing aims to reduce test efforts by automatically generating test cases from test models. In this paper, we introduce variability management to usage models, a widely used model-based testing formalism. We present an approach that allows to derive usage model variants from a desired set of features and thus generate test cases for each variant. The approach is integrated in the industrial model-based testing tool chain MaTeLo and exemplified using an industrial case study from the aerospace domain.
Informatique
MasterTexMPLM.pdf (2.25 Mo) Télécharger le fichier
hal-01025159 , version 1 (17-07-2014)
  • HAL Id : hal-01025159 , version 1
Hamza Samih, Ralf Bogusch. MPLM -- MaTeLo Product Line Manager. 18th International Software Product Line Conference (2014), Sep 2014, Florence, Italy. ⟨hal-01025159⟩
395 Consultations
335 Téléchargements
