REPET for Background/Foreground Separation in Audio - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2014
Repetition is a fundamental element in generating and perceiving structure. In audio, mixtures are often composed of structures where a repeating background signal is superimposed with a varying foreground signal (e.g., a singer overlaying varying vocals on a repeating accompaniment or a varying speech signal mixed up with a repeating background noise). On this basis, we present the REpeating Pattern Extraction Technique (REPET), a simple approach for separating the repeating background from the non-repeating foreground in an audio mixture. The basic idea is to find the repeating elements in the mixture, derive the underlying repeating models, and extract the repeating background by comparing the models to the mixture. Unlike other separation approaches, REPET does not depend on special parametrizations, does not rely on complex frameworks, and does not require external information. Because it is only based on repetition, it has the advantage of being simple, fast, blind, and therefore completely and easily automatable.
Rafii-Chapter.pdf (2.21 Mo) Télécharger le fichier
hal-01025563 , version 1 (18-07-2014)
Zafar Rafii, Antoine Liutkus, Bryan Pardo. REPET for Background/Foreground Separation in Audio. G.R. Naik and W. Wang. Blind Source Separation, Springer Berlin Heidelberg, pp.395-411, 2014, 978-3-642-55015-7. ⟨10.1007/978-3-642-55016-4_14⟩. ⟨hal-01025563⟩
265 Consultations
1193 Téléchargements
