Modelling and numerics for respiratory aerosols - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Communications in Computational Physics Année : 2015
In this work, we first deal with the modelling and the discretization of an aerosol evolving in the air, in the respiration framework, within a domain which can be fixed or moving. We also investigate basic numerical properties of the numerical code which was developped, and also focus on the influence of the aerosol on the airflow.
aynumHAL.pdf (406.18 Ko) Télécharger le fichier
hal-01044590 , version 1 (29-08-2014)
Paternité
Laurent Boudin, Céline Grandmont, Alexander Lorz, Ayman Moussa. Modelling and numerics for respiratory aerosols. Communications in Computational Physics, 2015, 18 (3), pp.723-756. ⟨10.4208/cicp.180714.200415a⟩. ⟨hal-01044590⟩
844 Consultations
424 Téléchargements
