Component-based modeling and observer-based verification for railway safety-critical applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
One of the challenges that engineers face, during the development process of safety-critical systems, is the verification of safety application models before implementation. Formalization is important in order to verify that the design meets the specified safety requirements. In this paper, we formally describe the set of transformation rules, which are defined for the automatic transformation of safety application source models to timed automata target models. The source models are based on our domain-specific component model, named SARA, dedicated to SAfety-critical RAilway control applications. The target models are then used for the observer-based verification of safety requirements. This method provides an intuitive way of expressing system properties without requiring a significant knowledge of higher order logic and theorem proving, as required in most of existing approaches. An experimentation over a chosen benchmark at rail-road crossing protection application is shown to highlight the proposed approach.
doc00022227.pdf (1013.01 Ko) Télécharger le fichier
hal-01197464 , version 1 (11-09-2015)
  • HAL Id : hal-01197464 , version 1
Marc Sango, Laurence Duchien, Christophe Gransart. Component-based modeling and observer-based verification for railway safety-critical applications. 11th International Symposium on Formal Aspects of Component Software, Sep 2014, Bertinoro, Italy. p 248-266. ⟨hal-01197464⟩
217 Consultations
323 Téléchargements
