A Paradigm for Learning Queries on Big Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Specifying a database query using a formal query language is typically a challenging task for non-expert users. In the context of big data, this problem becomes even harder as it requires the users to deal with database instances of big sizes and hence difficult to visualize. Such instances usually lack a schema to help the users specify their queries, or have an incomplete schema as they come from disparate data sources. In this paper, we propose a novel paradigm for interactive learning of queries on big data, without assuming any knowledge of the database schema. The paradigm can be applied to different database models and a class of queries adequate to the database model. In particular, in this paper we present two instantiations that validated the proposed paradigm for learning relational join queries and for learning path queries on graph databases. Finally, we discuss the challenges of employing the paradigm for further data models and for learning cross-model schema mappings.
ciucanu-data4u14.pdf (261.8 Ko) Télécharger le fichier
hal-01052676 , version 1 (07-05-2015)
Angela Bonifati, Radu Ciucanu, Aurélien Lemay, Slawomir Staworko. A Paradigm for Learning Queries on Big Data. First International Workshop on Bringing the Value of "Big Data" to Users (Data4U), Sep 2014, Hangzhou, China. ⟨10.1145/2658840.2658842⟩. ⟨hal-01052676⟩
225 Consultations
249 Téléchargements
