Physical Design Issues in 3-D Integrated Technologies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Design techniques for three-dimensional (3-D) ICs considerably lag the significant strides achieved in 3-D manufacturing technologies. Advanced design methodologies for 2-D circuits are not sufficient to manage the added complexity caused by the third dimension. Consequently, design methodologies that efficiently handle the added complexity and inherent heterogeneity of 3-D circuits are necessary. These 3-D design methodologies should support robust and reliable 3-D circuits, while considering different forms of vertical integration, such as systems-in-package and 3-D ICs with fine grain vertical interconnections. The techniques described in this chapter address important physical design issues and fundamental interconnect structures in the 3-D design process.
03130008.pdf (318.09 Ko) Télécharger le fichier
hal-01054273 , version 1 (05-08-2014)
Paternité
Vasilis F. Pavlidis, Eby G. Friedman. Physical Design Issues in 3-D Integrated Technologies. 19th IFIP WG 10.5/IEEE International Conference on Very Large Scale Integration (VLSI-SoC), Oct 2008, Rhodes Island, India. pp.1-21, ⟨10.1007/978-3-642-12267-5_1⟩. ⟨hal-01054273⟩
123 Consultations
118 Téléchargements
