Convex-Based DOR Routing for Virtualization of NoC - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Network on Chip (NoC) is proposed as a promising intra-chip communication infrastructure. A simple and efficient routing scheme is important for large scale NoC to provide the required communication performance to applications with low area and power overheads. Although mesh is preferred for NoC, virtualization may lead to irregular topologies. In this paper, we propose a Convex-Based DOR (CBDOR) routing scheme for the convex topologies. We demonstrate the connectedness and deadlock-freedom of CBDOR. This routing mechanism relies only on two bits per switch. Simulation results show that the area overhead of CBDOR switch is just 2.2% higher than that of traditional DOR switch, with the added complexity negligible. Therefore, the simplicity in the routing mechanism and switch architecture makes CBDOR more practical and scalable when compared to LBDR and FDOR.
Convex-Based_DOR_Routing_for_Virtualization_of_NoC.pdf (94.23 Ko) Télécharger le fichier
hal-01054963 , version 1 (11-08-2014)
Paternité
Guang Sun, Yuanyuan Zhang, Yong Li, Li Su, Depeng Jin, et al.. Convex-Based DOR Routing for Virtualization of NoC. IFIP International Conference on Network and Parallel Computing (NPC), Sep 2010, Zhengzhou, China. pp.462-469, ⟨10.1007/978-3-642-15672-4_39⟩. ⟨hal-01054963⟩
76 Consultations
130 Téléchargements
