Evaluating and Optimizing I/O Virtualization in Kernel-based Virtual Machine (KVM) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
I/O virtualization performance is an important problem in KVM. In this paper, we evaluate KVM I/O performance and propose several optimizations for improvement. First, we reduce VM Exits by merging successive I/O instructions and decreasing the frequency of timer interrupt. Second, we simplify the Guest OS by removing redundant operations when the guest OS operates in a virtual environment. We eliminate the operations that are useless in the virtual environment and bypass the I/O scheduling in the Guest OS whose results will be rescheduled in the Host OS. We also change NIC driver's configuration in Guest OS to adapt the virtual environment for better performance.
NPC10-_1569304995.pdf (98.43 Ko) Télécharger le fichier
hal-01054988 , version 1 (11-08-2014)
Paternité
Binbin Zhang, Xiaolin Wang, Rongfeng Lai, Liang Yang, Zhenlin Wang, et al.. Evaluating and Optimizing I/O Virtualization in Kernel-based Virtual Machine (KVM). IFIP International Conference on Network and Parallel Computing (NPC), Sep 2010, Zhengzhou, China. pp.220-231, ⟨10.1007/978-3-642-15672-4_20⟩. ⟨hal-01054988⟩
165 Consultations
3458 Téléchargements
