Two Improvement Strategies for PSO - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper proposed an improved particle swarm optimization algorithm (IPSO) to solve continuous function optimization problems. Two improvement strategies named "Vector correction strategy" and "Jump out of local optimum strategy" were employed in our improved algorithm. The algorithm was tested using 25 newly proposed benchmark instances in Congress on Evolutionary Computation 2005 (CEC2005). The experimental results show that the search efficiency and the ability of jumping out from the local optimum of the IPSO have been significantly improved, and the improvement strategies are effective.
Two_Improvement_Strategies_for_PSO.pdf (829.22 Ko) Télécharger le fichier
hal-01055064 , version 1 (11-08-2014)
Paternité
Quansheng Dou, Shasha Liu, Ping Jiang, Xiuhua Zhou, Zhongzhi Shi. Two Improvement Strategies for PSO. 6th IFIP TC 12 International Conference on Intelligent Information Processing (IIP), Oct 2010, Manchester, United Kingdom. pp.122-129, ⟨10.1007/978-3-642-16327-2_17⟩. ⟨hal-01055064⟩
134 Consultations
148 Téléchargements
