Specification of Embedded Control Systems Behaviour Using Actor Interface Automata
Distributed Timed Multitasking (DTM) is a model of computation describing the operation of hard real-time embedded control systems. With this model, an application is conceived as a network of distributed embedded actors that communicate with one another by exchanging labeled messages (signals), independent of their physical allocation. Input and output signals are exchanged with the controlled plant at precisely specified time instants, which provides for a constant delay from sampling to actuation and the elimination of I/O jitter. The paper presents an operational specification of DTM in terms of actor interface automata, whereby a distributed control system is modeled as a set of communicating interface automata executing distributed transactions. The above modeling technique has implications for system design, since interface automata can be used as design models that can be implemented as application or operating system components. It has also implications for system analysis, since actor interface automata are essentially timed automata that can be used as analysis models in model checking tools and simulation environments.
SEUS_2010_Paper_15_-_Actor_Interface_Automata_-_20100716_9.pdf (221.37 Ko)
Télécharger le fichier
