The Design and Development of Test Platform for Wheat Precision Seeding Based on Image Processing Techniques - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The test platform of wheat precision seeding based on image processing techniques is designed to develop the wheat precision seed metering device with high efficiency and precision. Using image processing techniques, this platform gathers images of seeds (wheat) on the conveyer belt which are falling from seed metering device. Then these data are processed and analyzed to calculate the qualified rate, reseeding rate and leakage sowing rate, etc. This paper introduces the whole structure, design parameters of the platform and hardware & software of the image acquisition system were introduced, as well as the method of seed identification and seed-space measurement using image's threshold and counting the seed's center. By analyzing the experimental result, the measurement error is less than ± 1mm.
0805--Qing_Li.pdf (207.2 Ko) Télécharger le fichier
hal-01055427 , version 1 (12-08-2014)
Paternité
Qing Li, Haibo Lin, Yu-Feng Xiu, Ruixue Wang, Chuijie Yi. The Design and Development of Test Platform for Wheat Precision Seeding Based on Image Processing Techniques. Third IFIP TC 12 International Conference on Computer and Computing Technologies in Agriculture III (CCTA), Oct 2009, Beijing, China. pp.352-358, ⟨10.1007/978-3-642-12220-0_51⟩. ⟨hal-01055427⟩
80 Consultations
273 Téléchargements
