Neutral Interface for Assembly and Manufacturing Related Knowledge Exchange in Heterogeneous Design Environment
The goals of this research are to provide overview
of the recent activities in the field of design of manufacturing and
assembly processes from the knowledge share point of view and propose a
solution how to connect products to the manufacturing or assembly
processes and suitable systems. The research conducted here starts with
the assumption of connectivity of three design domains: product, process
and system design domains. The characteristics of the product are
pre-describing the set of the processes needed to manufacture and/or
assemble the product. The description of the product defines constraints
for the suitable processes. The processes are pre-defining the system
requirements and constraining the set of systems capable of carrying out
the needed processes. From the technical point of view the goal is also
to provide an information architecture, where the relations exist
between these three domains.
Bibliothèque électronique [cs.DL]
